  #1
Old July 6th, 2006, 09:17 PM
nagel88 nagel88 is offline
Default 1977 70hp Mercury stator readings
I have been trying to test the stator on my 3-cyl. Mercury. I have found some of the info I need by searching, but I have an "extra" reading that no one seems to mention and may be the source of my problem.
Here are my results on my four-wire stator:
Red to Blue: 5.66k
Red to ground: 156 ohm
Blue to ground: 5.82k
I've never seen mention of a reading between the blue wire and ground. Should there be any continuity, and if so, what would the correct reading be?
  #2
Old July 7th, 2006, 01:04 AM
ricksrster's Avatar
ricksrster ricksrster is offline
Default Re: 1977 70hp Mercury stator readings
Blue to ground should be 5800 - 7000 Ohms. If you want the trigger readings they are white/black to brown = 800 - 1400 Ohms. white and purple = 800 - 1400 Ohms. Ignition coil promary 0.2 - 1.0 Ohm and secondary = 800 - 100 Ohms.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #3
Old July 7th, 2006, 02:19 AM
Thanks! I'm getting 1.25k to 1.32k on the trigger, within limits. On the coils, I've got 1 ohm across the screw terminals (green and black wires). Is the secondary measured from the spark plug wire socket to the terminal where the black wire is connected?
  #4
Old July 7th, 2006, 08:33 AM
ricksrster's Avatar
Yes.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
stator readings (and their effect)? PuckHog Mercury & Mariner Outboards 1 July 27th, 2006 12:14 PM
Stator Ohm readings, Johnson 70hp -91 Per Johnson & Evinrude Outboards 3 March 10th, 2006 02:09 AM
need buying advice 1977 70hp Mercury nagel88 Mercury & Mariner Outboards 6 November 26th, 2005 07:59 AM
stator ohms readings timmytes Mercury & Mariner Outboards 3 November 29th, 2004 02:57 PM
1977 175 mercury stator problem Virago85 Mercury & Mariner Outboards 23 March 30th, 2004 02:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
