Re: tracker replacement console
Karla,<br />I am not familiar with the party deck but I have an old 1985 Tracker Limited Edition Bass boat. They used a panel that was attached to the glass console. I too needed a new console and investigated the means of getting one. I was play around one day when I removed one of the other small panels to clean up some wiring connections. I discovered the pabel was the same on the back side as was the front except it did not have the labels marking the switches and so on. I have now turned all of my panels over and used dry transfers with a coat of clear enamel to label the switches. Looks almost new! Good luck..<br />****
