Re: Getting new Prop
It could go either way, depending on how the hull responds...you may gain some speed at the same RPM with More lift, or, it could pull the R's down a tad, but keep the same speed, and you may find that you need to raise the engine some with the larger diameter prop and increase both speed and RPM..<br />Let us know what ya get.
