  #1
Old July 2nd, 2006, 02:22 AM
Limex Limex is offline
Default Mariner 175 HP Ignition Problem
Initial Problem:
1) We took the boat to the lake, run about for 10 minutes. Then one or 2 of the cylinders dies, the engine lost power and the boat slow down to just above idling speed.
2) We turn off the engine. Check the engine to see what's wrong. I see gas and abit of smoke comes out of the middle caburators. The engine was able to start again, and run at about 1/4 of its max power even when we push it to wide open throttle.
3) Engine ran like that for 5 mins, then the dead engine kicked in for about 20 seconds and drop out again. When getting close to shore, we put engine into neutral, it dies, and can't be started again.
We did a few diagnostics:
1) We check for spark on every single spark plug.
Results: There are sparks on the 2,4,6(port side) but none present in the 1,3,5 (starboard side) The sparks makes by the spark plugs 2,4,6 are small blue, which seem to be insufficient by the manual desccription (SELOC Mariner Outboard Repair)
2) We swap ignigtion coils between 2 and 1.
Results: The coil from the cylinder 2, that was working, when connect and use for cylinder one, no spark produced. The coil from the cylinder 1, that was not working, when move to cylinder, sparks produced. So coils reuled out as the casue.
Question: Which should I check next?
1) I will be looking at connections in the switch box
Anyhting I should pay attention to?
Are there any fuses to check for?
2) I will open up the flywheel and check the stator. Mabe this is the casue too
Any area I should pay attention to for wear and tear that's not obvious?
Thanks for viewing,
Liem H
  #2
Old July 2nd, 2006, 08:50 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Mariner 175 HP Ignition Problem
Welcome to iboats.
Yer gonna need a manual. It's either the stator is no longer sending power to that switchbox, or the switchbox is getting it and not processing it. They're both expensive parts, so you don't want to guess. You can test the stator with an ohmmeter. A manual will help with that process. Or you can try swapping switchboxes. If the other cylinders fire, then it's the switchbox. If it's the stator, the same cylinders will still fire.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old July 3rd, 2006, 12:24 AM
Mucho Gracias, will post results
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 25 Ignition Problem Rock Hall Mercury & Mariner Outboards 9 August 24th, 2009 11:03 PM
Mariner Ignition CCM1001 Mercury & Mariner Outboards 0 July 22nd, 2006 05:06 PM
Mariner 9.9 4 stroke ignition problem stormin_norman Mercury & Mariner Outboards 2 April 10th, 2005 08:20 AM
25hp Mariner ignition problem LaChonce Mercury & Mariner Outboards 0 August 17th, 2003 03:30 PM
MARINER 40HP (1994) IGNITION PROBLEM JCH55 Mercury & Mariner Outboards 2 July 27th, 2003 12:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
