Hi Guys,<br /><br />I have read a bunch of the posts here, so let me see if I've got this right.<br /><br />3 blade props get higher rpms and mph because they are lighter and only have to push 3 blades thru the water. 4 blade props give a quicker hole shot, don't blow out as much when trimmed out, and have better response at cruising speed. <br /><br />In other words for if I want to go fast a 3 blade is preferable, but for normal operation and better handling a 4 blade is prefered. <br /><br />I have a SeaPro 17 CC, with a 1999 Yamaha 90hp, used mainly for fishing in Mobile Bay and the surrounding rivers. Max rpm rating for that engine is I beleive 5500 rpms, I usually run 38mph at 4500-4900 rpms with a well worn 13 1/4 X 17 aluminum prop, I very seldom run WOT. No trim tabs or foil, ventilation plate about 1" above keel.<br /><br />I don't care a lick about going fast, I just want to get there safely. Mobile Bay can churn up pretty good sometimes, and when running in that chop the motor will sometimes ventilate. <br /><br />If I understand correctly, a 4 blade prop will give me a better bite and possibly not ventilate as much, correct?? And since I don't care to take a beating running fast in a heavy chop, speed is of no importance. <br /> <br />Therefore a 4 blade SS 13 1/4 X 18 is better than a Aluminum 3 blade 13 1/4 X 17 for my circumstances, right??? <br /><br />Thanks for any help <br /> Gary
