Re: I finnaly bought a SST prop! Do you think it will make any difference?
Well, let's see. Everything is equal, except that the SST is a very efficient prop, by itself, and compared to aluminum (thinner blades, better entry of leading blade edges, less trailing edge drag, smoother blade surface). All else equal, for a given rpm, you should go slightly faster with the SST than the aluminum.<br /><br />How old is your outdrive (or engine, if OB). SS, including the SST, is almost twice as heavy as Al and can bang the hell out of lower unit gears. It's like a flywheel on the prop shaft. Make sure you don't slam from F to R, or vice versa.
