bcrosehill
- Apr 19, 2006
- 8
I have a 2004 pt 185 tracker aluminum boat. It has a 90 hp Mercury on it. I changed from the stock 12.75 x 21 aluminum prop to a 13 x 21 michigan match prop. The rpm's went from 5500 to 5600 at wot. I don't have a gps but the speed seems a little faster. It is running about 43 to 44 mph. It has a lot more lift now. It hurt my holeshot just a little so I drilled 3-1/8 inch vent holes. I haven't had it back out yet. The cavitation plate is about 1 to 1.5 inches above the bottom of the hull. If I raise the motor 1 hole what will this do to speed, rpm's, holeshot, lift, water pick-up, etc.
