June 30th, 2006, 01:10 PM
fuel pump repair/maintenance '81 115 HP Evinrude
Looking to test fuel pump this weekend. If failing--how do I repair it? My manual is vary vague. I have a fuel pump kit but no instructions.
Thanks in advance-
Stephen
June 30th, 2006, 01:40 PM
Re: fuel pump repair/maintenance '81 115 HP Evinrude
my manual just says
1. remove 4 screws holding body together.
2. separate body, dicard diapjram and chcek valves and gaskets.
3. assemble in reverse, with new diaphram, check valves and gasket.
good luck
__________________
FLORIDA GATORS
TEBOW Country
See you at the
2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
June 30th, 2006, 01:58 PM
I'd bet you got an aftermarket kit. OEM kits come with instructions.
Look in the FAQ section for "9.9/15 OMC engines" by The Machinist. I seem to recall a section in the article about doing the fuel pumps.
June 30th, 2006, 06:59 PM
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
July 3rd, 2006, 09:02 PM
Thanks for the link. Seems good for general principle but the pump described in the link is different that what I have.
I'm guessing it's about as simple as Tashasdaddy's instructions. I'll take a go at it this evening.
Thanks,
Stephen
July 3rd, 2006, 11:05 PM
I can't remove the plastic housing from the back metal casing. It looks like it is separated by two thin gaskets.
What's the best way of taking this apart?
Thanks,
Stephen
July 4th, 2006, 12:20 AM
Well I solved my own problem. I tapped the metal casing with a hammer while resting the edge of the plastic housing the edge of an anvil.
I didn't now how fragile the plastic would be but the gasket gave way first.
Now on to rebuilding.
Thanks,
Stephen
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
