great advice from everyone, thanks much d
I used my Black & Decker heat/paint stripper gun on a small spot on the the aft port corner, ( it took forever ), and revealed a gleeming satin aluminum finish.
I think I'll first try the aircraft paint stripper if I can find it.
and yes I've already removed most of the hardware 8)
I'm a little afraid of using the blasting method because I don't want to disrupt that beautiful satin aluminum finish, so I'm a little gun shy about blasting it.
I think I might replace the transom wood with Walnut or maybe Cherry wood.
Yes I agree... that windshield is worth it's weight in gold as far as trying to replace it, so it will go up into the attic until it's time to re-install it o
Thanks again for all the advice and input.
I really appreciate it.
John
PS) I just acquired a BEAUTIFUL 1972 Starcraft 15' Jetstream-V also with a 50 hp Johnson 50th anniversary series outboard and after 5 days of work it's ready to hit the water WOOT :} I posted a picture in the starcraft forum
