  #1
Old June 29th, 2006, 10:15 AM
Ginder75 Ginder75 is offline
Default 1967 Mercury 35 Reverse lock
serial number 2489015, Mercury 350, 35 hp Twin.
The previous owner installed a impeller water impellor prior to my purchase. However, I think he goofed along the way. The motor pumps water like you would not believe, but the reverse lock is not engaging (no movement at all). I have checked and rechecked my manual, and I am making myself more confused.
It appears that all the parts are there, but they are not moving when the motor is shifted from forward to neutral to reverse.
Can someone give me the short and dirty steps to aligning the separate cam? Can I merely seperate the lower unit a few inches from the motor, or Ginder75 I fully remove it?
Ginder75
  #2
Old June 30th, 2006, 12:16 PM
Default Re: 1967 Mercury 35 Reverse lock
I pulled my Seloc Manual again last night and there is no reference to a reverse lock and the lower unti section. I thought there were three shafts coming from the lower unit (drive shaft, shift selector, and the the water tube.) And it was my understand that on the shift selector there was a cam that engaged the reverse lock.
And it was possible to get proper operation (motor will shift from forward to nuetral to reverse without error) but the cam is not engaging the reverse lock.
Where did I go wrong?
I am painting the interior of my hull this morning and my project of this afternoon was dropping the lower unit and seeing if I can rotate the cam 180 degrees. Should I do this, or is there something else I need to consider?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp mercury will not lock down in reverse robertreed1973 Mercury & Mariner Outboards 3 April 17th, 2005 09:27 PM
Reverse lock system on 1980 20 HP Mercury JFNStuart Mercury & Mariner Outboards 1 June 8th, 2004 03:41 PM
reverse lock on mercury outboard r8rfan Mercury & Mariner Outboards 8 April 13th, 2003 02:38 PM
reverse lock on 1976 Mercury 115 steve7107 Mercury & Mariner Outboards 1 March 12th, 2003 03:36 PM
reverse lock on Mercury 35 manual tilt mikedaly Mercury & Mariner Outboards 3 August 12th, 2001 09:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
