Re: 1992 evinrude 40 hp wot rpm too low
I have almost the same setup, but an '88 40 hp, 16 foot aluminum bassboat. I can't remember, but I may have a different gear ratio in lower unit than you. If you search "40 prop" in the Johnson/Evinrude forum, you'll find several more discussions on propping the 40.<br /><br />Short story: I have a 13, 15 and 17 pitch prop. I HAD a stingray also, but ditched it because it's so dang thick I was getting a rooster tail (before I raised my motor).<br /><br />I read that your hydrofoil should ride nearly out of the water at WOT, if not you are getting alot of drag - especially with the Stingray. Unfortunately, with my boat, when I raise the motor that much, the prop breaks out on turns, and I have to throttle back until the prop catches again.<br /><br />I settled on a ss 15 for all-around use with my rig. This winter for trolling, I'll go down to the 13. The 15 is best for combined hole shot/top speed for my rig (we've been skiing and wakeboarding alot recently also). The motor is mounted 2nd hole from the top (cavitation plate slightly above bottom of boat).<br /><br />It costs nothing to raise the motor (put a chunk of wood under the skeg, loosen the bolts, and raise/lower the front of trailer with the jack). I'd mess with that first before spending the $$$ on a new prop (unless you find a smoking deal on an SS on Iboats like I did
)<br /><br />That's a great motor. Have fun!!
