Realgun
- Jul 31, 2003
- 2,484
walleyedhed do you know anything about or have you tested the Hustler aluminium props?<br /> <br />I had a fairly beat up old prop when I got my boat it blew out in corners and was overpitched as we boat at 5000ft. The 15 pitch seemed fime but motors turning only 4600rpm. Have no idea what the old prop turned. I believe its a 17 pitch. This is a light load just me and a camera. I always have a full 21 gallons of premix too. I can trim that prop all the way up and can't blow it out even on tight 360 degree rotation @ WOT turns . FUN!<br /> Then the prop took a beating at the putt-putt lake (no wake lake). 50 feet from shore and thought water was at least 3 ft deep. <br /><br />I have a 1988 Force 85hp, 17.5 Ft Capri Bowrider and calculated prop slip is 9%. Proper range for motor is 4500-5500rpm.<br /><br />I have not changed jets yet.<br />I did get another housing but is 13 pitch. Thank you iBoats!!!!<br /><br />Can I do anything else other than jets and lowering pitch to gain rpm? I really want to go faster. <br /><br />Engine replacement is not an option.
