  #1
Old June 25th, 2006, 03:57 PM
Gregjg Gregjg is offline
Default '90 9.9/15 evinrude, RPM's
my motor will start right up, idle fine, put it in gear and the idle is at about 700 RPMs . give it full throttle and the best she will get is 4000 RPMs when it should be about 6500-7000. any ideas? carb has been rebuilt, fuel filter too.
  #2
Old June 25th, 2006, 05:02 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: '90 9.9/15 evinrude, RPM's
Your motor should run about 5500 RPM's. If it is truly running good, then I would look at either the Tach, being on the wrong pulse setting (dial on the back) or the prop is the wrong pitch. You should have the Tach set on "6" pulse....
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old June 25th, 2006, 05:48 PM
Thanks for your reply.
My manual says it should run 5500 to 7000 RPMs (it use to run that at WOT), The OMC tach i bought says I should have it set on 6 if i have two yellow stator wires (one yellow and one yellow/gray) but i have 3 yellow stator wires and instructions say i should have it set on 5 which is where i set it (also old one was at 5). The problem is the boat is not getting up on plain like it use to (at about 5000RPMs). same prop and all. The boat is considerably slower (4000RPMs).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 Evinrude V4 90 HP Low RPM's skeeter 1 Johnson & Evinrude Outboards 5 May 21st, 2006 01:10 PM
rpm's on 225 evinrude sandy151 Johnson & Evinrude Outboards 11 November 4th, 2005 03:22 AM
rpm's for a '88 evinrude 120 V4? jjboor Johnson & Evinrude Outboards 5 September 2nd, 2004 04:22 PM
WOT RPM's For Evinrude 120 HP olmpilot Johnson & Evinrude Outboards 7 August 5th, 2004 06:00 PM
112 SPL Evinrude RPM's @ WOT Chappie Johnson & Evinrude Outboards 3 May 19th, 2003 05:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
