I have one of those inflatable pools which is great,but dealing with taking on and pulling off the cover.The cover is a tad bit over 24'long,12'wide so it can get heavy.<br />Im looking for a backyard handyman version that could be built for cheaper then the store bought models....The store bought models are made to mount to the top rails of an above ground permanent pool,not inflatable....<br />Im picturing 2 4x4 set in the ground,with an axel at least 12' long that will also have a crank on one end.I do have a 6' privacy fence that if re-enforced,I could use that to mount to.<br /><br />Total weight while the cover is damp is probably 50 lbs or so...Just a FYI<br /><br /><br />I dont have access to a welder at this moment,so please keep that in mind when giving opinions on how to make this thought in my head work.
