  #1
Old July 21st, 2004, 11:58 PM
boatster boatster is offline
Default Avon inflatable boat wood floor boards
Hi guys,first off I wanna say how cool this bb is. I've been all over this place soaking (pun intended) all the info you've put out. I have a question though, I have an older Avon 12' inflatable with wood floor boards. The boards are getting very ratty so to speak. I want to make/replace the three main boards. My question is what wood do I use? Can I use Pine and the Epoxy coat the puppies? Or do I have to use a hardwood like oak and then coat the puppies with epoxy like CPES? What would you recommend. BTW I plan on always disassembling the boat after every days use so its the boat won't be in the water 90% of the time. OF course the boards will probably be wet 99% of the time while I'm in the water (going in the ocean). Thanks in advance for any info/suggestions.Adam
  #2
Old July 22nd, 2004, 10:02 PM
tgissel tgissel is offline
Default Re: Avon inflatable boat wood floor boards
Adam you might just use pressure treated plywood, it alone will last and not be very expensive. You can also sand it and then varnish it for a good look also. Starboard is another option but pretty expensive it is made of a plastic type polymer and is gas and oil resistant and should outlast the boat. Good Luck. Thad
  #3
Old July 22nd, 2004, 11:06 PM
Thanks for the info Thad.I just stopped by Home Depot and looked at the pressure treated plywood, $36 for a huge 4' x 8'. I can also buy single 2' x 4' for single board replacement @ $16. Now if only I could find the extruded aluminum stringers that join the two boards together. My current boards aren't like that. I wonder where I'd have to go to get that aluminum?Adam
  #4
Old November 2nd, 2006, 06:25 PM
gxxdman gxxdman is offline
Hi - I replaced one of mine with plastic planks used in the building trade 150mm x 10mm ie exactly the same size as original wood ones which are now all broken. I shall replace all the others shortly. It comes in 4 or 5m lengths here and is used by double glazing firms who often have off cuts. I notice that Avon also use plastic now.
It is bendier, but seems almost unbreakable. Make sure you sand and round off ends after cutting.
Good luck - John (Scotland)
  #5
Old November 4th, 2006, 12:35 PM
ventura tim ventura tim is offline
I used 3/8" cdx plywood and then painted on 2 coats of elastomeric waterproofing. The plastic interconnect channels were ordered from Avon.
  #6
Old November 11th, 2006, 10:53 AM
Nos4r2's Avatar
Nos4r2 Nos4r2 is offline
The original boards are just hardwood marine ply with varnish-you won't go far wrong replacing them with the same.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
HELP with installing wood floor boards jmingst Avon Boats 2 February 8th, 2007 11:45 PM
Inflatable Boat Wood Floor Replacement Guidance bavmw Boat Restoration and Building 2 May 31st, 2006 03:14 PM
Painting floor boards in Zodiac inflatable crazy charlie Zodiac Boats 12 November 23rd, 2005 03:48 PM
Painting floor boards in Zodiac inflatable crazy charlie Boat Topics and Questions (not engine topics) 10 September 27th, 2004 04:30 PM
Avon inflatable boat wood floor boards boatster Boat Restoration and Building 2 July 22nd, 2004 11:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
