  #1
Old June 19th, 2006, 09:27 AM
brionnewell brionnewell is offline
Default Bulkhead repair?
Hello all, I picked up a 5 year old Zodiac 340 Fastroller over the weekend that appeared to be in good shape until I deflated it for the first time. My understanding is that there are 3 tubes + keel + floor. However, when I opened just the side valve to deflate it also deflated the front chamber (what I think is a separate chamber).Has anyone here ever dealt with a compromised bulkhead? If so, what did it cost to get it repaired (I'm assuming this is something I won't be able to do myself).Thanks.
  #2
Old June 20th, 2006, 08:00 PM
Snowdrggn Snowdrggn is offline
Default Re: Bulkhead repair?
Brion, Before you panic about having a blown out bulkhead, pump the rear (side) tubes up to about 1 1/2 psi (about 1/2 regular pressure). Leave the valve open in the front section. Leave the boat sit in an area where the temperature is stable for 24 hours, then check to see how firm the tubes still are. If they haven't sagged a whole lot I wouldn't worry about it. A bit of seepage is quite common. Remember the bulkheads are really only there to let you get to safety in the event of a tube puncture, not to spend the day on the water with a flat tube. Let me know what the results of your test are?Cheers, Snow.
  #3
Old June 24th, 2006, 12:23 PM
Vlads Quiff Vlads Quiff is offline
Quote:
  #4
Old June 25th, 2006, 06:10 AM
OOPS!!
Sorry, what I meant to post was...............
You have got me a bit worried.
I too have just brought a used Fastroller (3.1).
I think I only have two tubes that inflate (the main side ones) as it is a smaller boat. I too have an inflatable floor and keel.
When I inflated it in my garden both tubes seem to blow up from the one valve. The instructions did say that each tube should only be inflated 50% before doing the other.
What is the construction of the tubes? Is each tube completely separate from each other.
I am confused.
thanks
  #5
Old July 1st, 2006, 12:54 AM
TOHATSU GURU's Avatar
TOHATSU GURU TOHATSU GURU is offline
There is a fabric baffle between the two tubes. As the boat nears the end of its life the baffle fails. The baffle can also fail due to pumping one tube up to full inflation without having any air in the other tube.
__________________
Elvin
My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
My Three Rules:
1) Look in your service manual first.
2) Have basic mechanical skill.
3) If you are confused, take your engine into a dealer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
the bulkhead came out in pieces how to construct new ? imported_DANA Boat Restoration and Building 5 February 28th, 2007 10:15 AM
What's the dif, in a repair manual and a tune-up/repair manual? CN Spots Non-Repair Outboard Discussions 4 February 26th, 2006 11:47 AM
OMC 3.0...repair or not? trentmh Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 March 26th, 2005 02:53 PM
Wannabe Bulkhead jimmythekid Boat Restoration and Building 10 February 2nd, 2005 04:47 AM
Repair tip. alcan Non-Repair Outboard Discussions 3 October 29th, 2003 06:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
