  #1
Old January 22nd, 2006, 10:20 AM
summerwind1991 summerwind1991 is offline
Default Problem with Depth Finder
I have Sea Ray 250DA, 1997. Depth finder flickers back and forth from 1' to 2', no matter what depth I'm at. Where in the bilge area is the depth finder? Thank you.
  #2
Old January 22nd, 2006, 12:47 PM
Manipulator Manipulator is offline
Default Re: Problem with Depth Finder
I have the same problem. My depth finder is a Hummingbird and not sure if it was original equipment or the previous owner added it. Again, having the same problem going to 1-2 feet and then just staying on one or the the other. Mine will act goofy and then will work fine all day. The problem seems to be intermittent.The sensor should be attached to the transom on the back of the boat. At least mine is.
  #3
Old January 22nd, 2006, 03:26 PM
dartguy dartguy is offline
Is the depth finder factory installed or was it installed later? The transducer can be in a couple of spots. Aftermarket depthfinder or fishfinders can have the transducer mounted on the transom. If it's a factory installed depth finder, the transducer can be a thru hull style. It would be in the bilge. You could see it from underneath as a round flat black disc. Has it ever worked? Was it recently installed? Transducers operate at only 2 frequencies. For example, if you have a factory depth finder, and you install a depth/fish finder, the transducers could be using the same frequencies and would then cause erratic readings. If that isnt the case or it did work at one time with no new instruments installed, you could have a failure.
  #4
Old January 23rd, 2006, 04:23 AM
Dart Guy, thanks for the response. Yes, it is factory installed. There is this black round, circular thing very easily accessible at the bottom of the bilge area, it had vent type arrangments around it ...I thought it was the bilge pump.Could this be Depth finder? Can I just unscrew it? It looks to be very, very solidly attached to the hull. Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fish finder/ depth finder for a newbie nightvision Electrics, Electronics and Trolling Motors 4 April 11th, 2007 04:59 PM
LCR100 Depth Finder Problem buchananjahnke Electrics, Electronics and Trolling Motors 1 August 19th, 2004 01:39 PM
Raymarine depth finder temp problem rkhanso Electrics, Electronics and Trolling Motors 2 May 15th, 2004 02:28 PM
Lowrance depth finder problem mojokim Electrics, Electronics and Trolling Motors 0 October 29th, 2003 04:29 AM
Depth Finder Problem- Need Help BeerBarge Boat Topics and Questions (not engine topics) 2 August 4th, 2002 11:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
