Nos4r2
- Dec 12, 2004
- 1,533
Hey lubedude or oildoc, is there any way of telling whether or not an oil is designed to take the higher temperatures that an aircooled high-revving engine produces?<br /> I'm trying to find something that I can put in my girlfriend's street legal aircooled ex-dragbike. <br />At the moment it's using the generic castrol 10/40 motorcycle oil but we're noticing that the gearshift becomes noticeably notchier after 1000 miles and changing the oil at that point.The gearbox is absolutely perfect, no noticeable wear on selectors or gears.<br />I'm going to be fitting an oilcooler to it soon anyway but even then the oil will be taking a real hammering in comparison with a liquid cooled low-revving car engine.<br />It hits 11000 rpm on a regular basis and with the kind of internal tolerances required to run as hot as it does there's quite a bit of blow-past from the combustion process when cold.<br />Also, what's your opinion on Slick 50 and other one-time teflon oil additives? The engine is a 'unit' construction so the engine shares its oil with the gearbox and the oil-bathed clutch.<br />This means any additives that go in the oil at every change are a no-no as they make the clutch slip like mad-even with the heavy duty clutch and springs in there.If I use a one-time teflon additive I'll put an old clutch in for the duration of the treatment.
