  #1
Old December 23rd, 2005, 03:20 PM
recess recess is offline
Default 1976 Gulfstream Update
Updating a '76 Gulfstream W/A with OMC 3 liter to outboard. Engine and outdrive out, transom already sealed, glassed, and gelcoated (thanks to this forum for all the advice) and bracket and Yamaha 175 mounted.Getting ready to install Seastar hydraulic steering, electrical, and throttle/shift. Any advice or input from similar updates would be appreciated. Since there is not a whole lot of activity on this site, thought I'd try to get some tips and advice flowing. I need recommendations on how to run the hydraulic hoses through the transom; power and electical through hoses to the engine. I have some ideas, just want to confirm my suspicions with already tried and tested refits.2manyboats: read your posts from earlier about transom repair. I have some experience with how its put together as this is my second Grady that I've done some transom repair to. Just read it tonite however and I see the post is closed.
  #2
Old August 18th, 2006, 12:33 PM
Default Re: 1976 Gulfstream Update
Things are coming along slowly, not due to problems but time and the heat. All hydralulics are in and working great. Its amazing how good things can work out if you actually stop and read the instructions! Rewired the boat with new guages, switches, and dash.
Now that I can move around the boat and see how its built, these really are solid boats. I do have one observation that I need some help with. There appears to be many areas under the deck on either side of the original motor well that is sealed in with no means of getting into. I can only assume that these are filled with foam and sealed up. Also, up forward on either side of the cabin floor,under the seat cushions, large void areas also sealed and probably filled with foam. I would appreciate a response from someone knowledgable about these designs if this is indeed the case. Also, should I plan on cutting an access hole to these voids to check the condition of the foam? The exterior is solid with no signs of damage, but in reading about how foam absorbs water from the smallest areas, I would just like to know for safety.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How about Gulfstream Inc.? Boomyal Suggest a Boat Manufacturer Forum 1 November 13th, 2006 11:28 AM
Gulfstream Boomyal Suggest a Boat Manufacturer Forum 0 May 19th, 2006 09:51 AM
Gulfstream Update-THE CHAMPAGNE BOTTLE HAS BEEN BROKEN! Boomyal Boat Restoration and Building 108 September 5th, 2005 05:03 PM
'78 Grady 20' Gulfstream FreeBeeTony Boat Topics and Questions (not engine topics) 1 May 20th, 2003 09:29 PM
GulfStream???????? steve forsythe Freshwater Fishing 1 February 26th, 2002 03:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
