  #1
Old December 1st, 2005, 08:16 AM
btr0037 btr0037 is offline
Default towing a 17 foot whaler
I have a 1971 17 foot Katama with a newer Mariner 90 onit. The trailer is a substantial galvanized nontilter with one axle. I am looking to buy a used Dakota pickup which has a rated towing capacity of 2000 lbs. I have no idea of the weight of my boat and trailer. Does anybody have an idea if this will work? I would prefer not to buy the larger 1500 model truck.
  #2
Old December 1st, 2005, 09:25 AM
JB's Avatar
JB JB is offline
Default Re: towing a 17 foot whaler
You will be right on the edge, Katama. Both my 16 Sakonnet and my Montauk 17 weighed right at 2,000lb ready to launch.I towed the Sakonnet with a Toyota pickup with a 2,000lb rating and it worked very hard, particularly on retrieval. Braking was a dicey affair on wet or in a hurry.I later towed it with a Wagoneer rated at 5,000lb and I always towed the Montauk with an ML (also 5,000lb). Either were very secure and effective.I think the 2,000lb rated Dakota would fall short and disappoint you. You might look into what would be required to raise the rating, but I am afraid that would involve changes in gear ratios and springing as well as the usual "tow package" add-ons.
__________________
RED SKY at night. . .
JB
  #3
Old December 2nd, 2005, 06:08 AM
KeltonKrew KeltonKrew is offline
I would be more concerned with braking. Everyone thinks power/gears for towing. You must have adequate breaks. Once you get moving, you have to stop!
__________________
1996 18' Premier Odeski Tri-Toon w/ 120hp Force
1964 13' Boston Whaler Custom Center Console with 1986 Merc 35
2004 Honda Aquatrax F-12x
  #4
Old December 6th, 2005, 01:39 PM
Thanks for the input. The 1998 Dakota (the one I am contemplating) has a towing rating of 6900 lbs and a payload of 1700 lbs. I have never owned a truck and do not know what the figures really mean. Can such a rated truck tow the 2000lb Katama? I would hope the brakes would be designed in accordance with the towing and payload capacities.
  #5
Old December 6th, 2005, 03:00 PM
if the tow rating is 6900, yes you could tow this boat, you should have ample brakes, etc.the payload is what you put in the bed, fuel, people, tongue weight.on a 2000lb boat, the tongue weight should be well within the payload rating.tow rating is what you're pulling. payload is cargo/fuel/people/tongue weight, etc.make sure it has a transmission cooler as this is a weak link. if not, you could burn a tranny! (especially while backing up)hope this helps
__________________
  #6
Old July 3rd, 2006, 12:46 AM
rbruce63 rbruce63 is offline
Can a Montauk 17 with a 90 Hp two stroke be towed safely without a braked trailer over mountainous roads with a GMC Jimmy with a 4.3 liter V6, 3.73 gear ratio, radiator integrated engine oil and transmission oil cooler?
  #7
Old July 19th, 2006, 01:03 AM
airwarrior airwarrior is offline
rbruce I'd check with GM just to be sure... I dont know how much they take "mountiaous roads" into consideration when they build it. But like as mentioned in this thread, all gased and ready to hit the water you are real close to 2000 pounds. If you were towing on flat, or hilly country I think you'd be ok... but you did say mountainous and that sounds like the brakes, transmission and engine will be working much harder. What year is the Jimmy? You can get lots of upgrade parts for them, drilled rotors and higher performance pads would be a good start, that is assuming the vechicle is generally in good mechanical condition.
  #8
Old March 9th, 2009, 09:26 PM
shes a keeper shes a keeper is offline
I agree but that 4.3 l is a power house for a short block I had a 1988 astro van and I pulled my montauk with a 100 merc 2 stroke with no problems at all and no brakes on the trailer in N .J but It was the average hill climbs.. brakes are the big answer, good luck <*)))-}} brakes on trailers are the ticket, it`s alot safer as airwarrrior stated check with gm
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What's your Whaler? JB Boston Whaler 69 December 15th, 2008 11:56 PM
50hp, 13 foot Boston Whaler, Prop Tom P Prop Questions and Topics 0 January 16th, 2007 11:55 PM
Whaler & Whaler/Merc swist Boat Topics and Questions (not engine topics) 1 June 13th, 2005 06:51 AM
Whaler 62 jsfinn Boat Topics and Questions (not engine topics) 4 January 23rd, 2004 12:46 PM
15 Whaler 140 AW Boat Topics and Questions (not engine topics) 7 January 22nd, 2004 01:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
