  #1
Old June 20th, 2006, 09:30 PM
jkm2730 jkm2730 is offline
Default 99' Capri 1750 tachometer / fuel gauge issues
Just got my new, to me, boat out today and noticed the following things:The tachometer jumps around. Its not dead and sometimes I think it pretty close to correct but it would sometimes be between 5k and 6k when we were just doing 5-10mph. Sometimes I could toggle the bilge pump on and off and the tach would partially or mostly recover and then work for a while but never 100% of the time.The fuel gauge worked fine when we were filling up the tank as I watched it go from 1/4 to 3/4 during our stop at the gas station. While under way the fuel gauge just continued to jump between maxed out and 3/4 or as the fuel level started going down it would jump between 1/2 and full. Now while sitting in the driveway the fuel gauge reads solid between 1/2 and 3/4.All of the other gauges seem to operate good and appear stable during operation.Any ideas?thanx,jeff
  #2
Old June 21st, 2006, 04:48 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: 99' Capri 1750 tachometer / fuel gauge issues
Boat Questions and Topics (non engine topics)Welcome to iboats.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old July 26th, 2006, 02:47 PM
Beaverfan Beaverfan is offline
Hey Jeff. Fuel gauge is going to bounce quite a bit depending on if you are throttling up or down, on plane or coming onto plane. Mine does the same thing. If I am going steady on plane and not taking on rough water the fuel gauge stays somewhat fixed but does move some. I have a 2001 Capri 185.
As for the Tach, I had the same problem one time and was concerned. I checked my wiring and everything seemed to be in line. Then the problem simply stopped and I have not had it reoccur.
  #4
Old August 14th, 2006, 11:32 PM
yelladog yelladog is offline
I have the same problem with my tach, same boat same year. My tach is stuck at about 1,500R.P.M. I never did find the problem. Bad tach maybe.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
99' Capri 1750 tachometer / fuel gauge issues jkm2730 Boat Topics and Questions (not engine topics) 2 June 21st, 2006 08:35 AM
Have 2 ?'s about my '94 Capri 1750 jeffyjeff Bayliner Boats 1 June 20th, 2006 06:26 AM
2 ?'s about my '94 Capri 1750 jeffyjeff Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 20th, 2006 03:26 AM
Fuel gauge issues aweiss44 Boat Topics and Questions (not engine topics) 3 May 25th, 2004 08:06 PM
1989 Capri 1750 CS doyle101 Non-Repair Outboard Discussions 3 April 13th, 2002 04:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
