  #1
Old June 19th, 2006, 09:07 PM
jkm2730 jkm2730 is offline
Default 99' 1750, pull skier with aft cleat?
New boat owner here with a 1999 1750 Capri 3.0 ltr. I want to pull skiers and tubes but I am worried that the aft cleat isn't strong enought. I've seen other 1750's online with the s/s ski rings but they appear to be bolted into the same holes. Is it possible that the ski rings are bolted in with some support behind the bolts to dispurse the force. From what I can see my aft cleat is not reinforced. Here are a couple of links to show what I am looking at. Any help is appreciated.thanx,jeff AFT SHOT INSIDE SHOT
  #2
Old June 20th, 2006, 02:31 AM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
Default Re: 99' 1750, pull skier with aft cleat?
In my unqualified opinion, the mounting position does not look strong enough.
__________________
Watch this space......................
  #3
Old June 20th, 2006, 07:21 AM
imported_John_S imported_John_S is offline
I have the same cleat type for the ski tow, on a '97 Capri CL. It has the stainless washers on the back too. I don't remeber how my transom was laid up in that area, but yours looks to have additional thickness of plywood plus the angled pieces for support. I have pulled single tubers, single knee boarders, and single skiers, with it. There has not been any cracking at all near the cleat. I bought a two-person tube this year, and may add an additional plate or larger washers, to distribute the forces, further. Many people use the tow tie downs with a ski harness. It distributes the forces across two rings. On my bayliner, those tie down rings are backed by stainless washers, too. One draw back of using the tie downs is that the ski rope will be in the water more.
  #4
Old June 23rd, 2006, 11:19 PM
Purduebarry Purduebarry is offline
Silly Bayliner, give us a freakin pole or something, I too use the "Y" harness and the trailer tie downs. I have the cleat in the middle but don't trust it. Yours looks much stronger. Use it and keep a close eye on it. If you start to see any small spider cracks in gel, then you'll have your answer. A 1999 is pretty new, I'd call Bayliner and ask, or replace the cleat with a bigger cleat and put a big 4" x 6" SS plate behind it. That should distribute the pressure and unless you pulling Shamo you should be okay!
  #5
Old June 23rd, 2006, 11:21 PM
By the way, is that a swim tube with a cut down the seam on your windshield? What a great freakin idea. Keeps the pressure off the cover and the glass, you think of that or was it like that? Can't wait to get out the knife!
  #6
Old June 28th, 2006, 06:07 PM
msd58's Avatar
msd58 msd58 is offline
Should be OK, nice looking boat too.
  #7
Old June 29th, 2006, 03:24 PM
eeboater's Avatar
eeboater eeboater is offline
Just got back from a whole weekend of boating, tubing and skiing.
Let me say with as much seriousness as I can possibly convey - get a tow ring AND reinforce it.
Last weekend was the first time I have ever pulled someone with our boat and the amount of strain on that tiny piece of hardware was so much more than I ever imagined.
Here's an example... I have a regular, run-of-the-mill 125 cm tube. The bottom of the tube is surrounded by a piece of nylon which presumably allows the tube to glide across the water easier. Well, if the person falls off the tub incorrectly, and it flips over, the tube creates a huge suction as it glides across the water - to the point that it seems like I deployed a parachute behind my boat.
I can guarantee that if I didn't reinforce that towring with a 3/4" piece of wood with 1.5" diameter washers that spanned the width of the stern of my boat, that tow ring would have been yanked out of the back of my boat. Not only that, with the stretchyness of the tow rop - that would have made a nice dent in the head of whoever was riding on the tube.
Better safe than sorry - reinforce that ring - don't rely on the cleat.
  #8
Old July 4th, 2006, 08:34 PM
eippermx eippermx is offline
I have an '88 1950 and use a tow harness with float (buy 'em all day long at Wal-Mart for $18) attached to the tie down points. Never had an issue with the tow rope being lower in the water.
  #9
Old July 4th, 2006, 08:35 PM
Hmmmmm...that should be eigtheen bucks....
  #10
Old August 14th, 2006, 11:36 PM
yelladog yelladog is offline
I have the same boat same year, but mine has the round eye. Dont know???
  #11
Old August 24th, 2006, 01:23 AM
laurido1992 laurido1992 is offline
I had the same boat but mine came with a ski tow ring. I recommend you chnge it and if possible get some steel platesto use as backing support. Something at least 1/4" thick.
Good Luck
  #12
Old August 24th, 2006, 05:18 PM
I think they just ran out of tow eyes that day when they built the boat. The manual for that year/model shows it is suppose to have a tow eye.
7. 14557 SKI TOW S/S 1.0 EA
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
65hp will it pull a skier bsh21wash Non-Repair Outboard Discussions 15 May 15th, 2006 07:33 PM
Minimum Outboard HP For 16' To Pull A Skier? TheMayor Boat Topics and Questions (not engine topics) 5 May 17th, 2004 08:49 PM
50HP pull a skier? sunbird 15ft Bunnerrabbit Non-Repair Outboard Discussions 4 June 19th, 2003 03:27 PM
Enough to pull skier? bh357 Boat Topics and Questions (not engine topics) 5 June 13th, 2003 11:03 AM
Can't pull up a skier? Wrong prop??? blacksmith Boat Topics and Questions (not engine topics) 12 July 29th, 2002 12:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
