  #1
Old June 17th, 2006, 09:11 AM
Rob454 Rob454 is offline
Default prop question
Ok guysI have a 89 Bayliner 19 foot Capri open bow. it had a 5 liter v8 and OMC outdrive. I jsut had the motor replaced and it runs great. The only thing is the boat only revs to 36-3700 RPM. but it was sort of rough out that day. It has great pick up off the bottom. Now I looked and i saw the last owner had a 4 blade prob and there is a 3 blade prop in a storage bin. The 3 blade prop looks like it got dragged up a launch ramp or hit something so its unuseable. Now I had jet skis and When you switched to a different prop you could loose as much as 500RPM from the top. Anyway I know a a bunch about jet ski props and wont bore you. Im thinking I should go back to my stock 3 blade prop. I dotn plan on towing skiers and If I do the prop is a snap to change. What is the stock prop for that bayliner?ThanxRob
  #2
Old June 17th, 2006, 09:14 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: prop question
Hey Rob, I will get this to the prop forum, but will leave it open here also.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old June 23rd, 2006, 11:01 PM
Purduebarry Purduebarry is offline
Rob,
I have an 1988 version of the exact same configuration, 5.0L, OMC. My manual says RPM's should be 4200 to 4600 at WOT. That 4 blade must have a really high pitch? The three was probalby original. My set-up has a 14.5 x 19. This is the OEM configuration.
Check here on i-boats they have a selection tool and also the Michigan Wheel web site has a great selection tool.
You MUST be wihtin your suggested RPM range at WOT. That is the law, anything else is a slow death for the engine, drive or both. Over prop and the engine will labor, under prop and it will over rev. Increase pitch = lower RPM and decrease pitch = higher. If everything is correct, tach, speedo, tune up of engine etc. you should be at 4400 RPM's at WOT.
With a light load on smooth water you'll get around 45 MPH, give or take 5 MPH depending on conditions. A higher pitch prop (assuming what you have now) may get you faster top end but your killing the motor and drive. You want efficiency right now you don't have it. Also this is assuming your not carrying around a ton of water logged foam. That's another subject I'm in the midst of correcting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Prop or Old prop, that is the question . . . boatingbob Prop Questions and Topics 1 August 14th, 2006 10:04 AM
Prop question, and results from my spun prop. Big-E Prop Questions and Topics 4 September 23rd, 2005 05:02 AM
Prop Question kyearber18hp Johnson & Evinrude Outboards 6 August 30th, 2002 05:02 PM
prop and prop shaft question Lugnut36 Johnson & Evinrude Outboards 4 August 15th, 2002 08:32 PM
Prop question...again! sorry.... Jersey13 Mercury & Mariner Outboards 5 May 4th, 2001 09:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
