  #1
Old May 12th, 2006, 11:05 AM
rg33 rg33 is offline
Default 1983 Bayliner Capri 1600 w/ a ??hp outboard
Just got this ( 1983 Bayliner Capri 1600 )with a Force outboard. There is not an obvious motor id tag, but the cowling has 85 on it. Can someone tell me what the model number of the outboard would be without power trim and tilt? Is there another way to determine the model without disassembly?
  #2
Old May 12th, 2006, 11:19 AM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: 1983 Bayliner Capri 1600 w/ a ??hp outboard
Not a tag on the transom mount?
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old May 12th, 2006, 11:30 AM
None visible. Have a clymer book that was given with boat and I looked in the 2 locations per the book and found nothing. What would model numbers be for that year outboard? BTW I was born in Somerset, KY
  #4
Old May 12th, 2006, 06:13 PM
javsam javsam is offline
is there any model listing on the transom clamps?javsam
  #5
Old May 12th, 2006, 07:14 PM
I am assuming that you mean the tag or sticker that indicates the model and serial numbers. And there is nothing like that on either side of the mounting frame or motor housing. It is a 3 cylinder engine and the plugs are NGK BUHX, if that will help.
  #6
Old May 13th, 2006, 06:15 PM
Realgun Realgun is offline
Try posting in the Chrysler force forum in engines.You may need to ask a mechanic to identify it though.90% of the 85's are the same just a few things are different. Go by the year you believe the boat is as they came with the boat unlike other MFG where they sold you the boat and then offered you a motor of their choice.
  #7
Old May 13th, 2006, 06:26 PM
Thanks, I thought of posting my question there, but did not want to make dupilcate requests and get the moderator mad at me.
  #8
Old May 13th, 2006, 06:44 PM
Never mind, I checked and asked another source that noted that the tag could be under the carbs. Sure enough, it was there 856X3L
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 bayliner capri AQ125 A Volvo rbethart Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 14th, 2008 10:47 PM
1983 bayliner capri AQ125 Volvo rbethart Bayliner Boats 1 August 30th, 2006 09:41 PM
RPM GUAGE VOLVO/Bayliner Capri 1983 eyezaiah Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 September 3rd, 2004 07:35 AM
1983 bayliner capri trim problems jerry32 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 21st, 2004 07:19 PM
1989 Bayliner 1600 Capri+ Force 50 hp Les Williamson Boat Topics and Questions (not engine topics) 6 December 11th, 2003 08:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
