  #1
Old May 8th, 2006, 12:00 PM
JAL51974 JAL51974 is offline
Default throttle control problem?
i posted this question on another part of the forum and thought someone here might be able to answer it as it pertains to Bayliner.This is a single lever control with only one button underneath the handle that is the neutral safety switch, preventing you from accidently engaging the throttle. Depressing the button shifts the engine into gear. There appears to be no other button or manner of disengaging the prop in order to give it more gas like when you are warming up the engine. Not sure about the model, seems to be original equipment on this old boat! Any suggestions of what to do short of replacing it with a more modern throttle control?
__________________
"SeaDog"
1985 Bayliner Capri 1950 BR
AQ125a/270
Even a bad day on the water is better than a day at work!
  #2
Old May 8th, 2006, 02:05 PM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: throttle control problem?
Joe, sometimes they had a button where the lever pivots that you could push in while pushing shift control forward. I have seen some that the whole lever will pull out toward you to activate warm up mode. Hard to say which if any you have.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old May 9th, 2006, 09:13 AM
The only button on it is the neutral safety and depressing it allows the shifter to shift it into gear. the handle does not pull up as some do allowing the throttle. someone suggested that the lever might move toward the middle of the boat allowing throttle only. Is that what you mean by pivoting? I haven't tried that yet.
__________________
"SeaDog"
AQ125a/270
  #4
Old May 9th, 2006, 03:34 PM
Yes Joe, toward the center of the boat. Sometimes they work that way just for warm up.
__________________
  #5
Old May 10th, 2006, 01:14 PM
I'll try that and let you know. Won't be for a couple of weeks though as I am recuperating from surgery, had 5 bypasses, quite a shock since my cardiologist just thought it was going to be a simple stent. for now I am land locked!
__________________
"SeaDog"
AQ125a/270
  #6
Old May 10th, 2006, 04:15 PM
Ah man, sorry to hear.Yea, take it easy and let that ol ticker heal up good.We will still be here.Hoping the best for a fast recovery.
__________________
  #7
Old May 29th, 2006, 03:16 PM
Here is the result of further investigating this control unit. It does pivot towards the center of the boat and can be moved forward. But in that position the ignition won't start. Ignition is only capable in the Neutral position of the control so still cannot get a throttle only conditon. I found a owners manual recently from Bayliner for this 1950 capri bowwrider cx. It indicates using the method described above leaving it in 1/4 throttle position to engage the key to start position but this does not work on mine. any ideas of what to troubleshoot?
__________________
"SeaDog"
AQ125a/270
  #8
Old May 29th, 2006, 04:13 PM
Hey Joe, don't know if you are doing it this way, but maybe do not pull up on the little button underneath to change it's gears. Just leave it alone and see if it won't move.
__________________
  #9
Old May 30th, 2006, 09:42 AM
tried that too still cannot start it, will only start in Neutral. funny that the manual instructions don't work? only other thing I can think of is there is something not quite adjusted right where the throttle/gear cable connects at the outdrive. there is a caution in the repair manual about not adjusting that linkage too far one way or the other or else you might lose your Neutral. maybe that has something to do with my problem?
__________________
"SeaDog"
AQ125a/270
  #10
Old May 30th, 2006, 10:39 AM
Joe, is this an I/O engine or O/B?
__________________
  #11
Old May 31st, 2006, 08:49 AM
It is an I/O engine.This is turning into a real puzzle.Any other 1985 era Capri Bowrider owners out there with a similar Bayliner standard control?
__________________
"SeaDog"
AQ125a/270
  #12
Old May 31st, 2006, 04:03 PM
Joe, I will move this over to the Merc/Volvo, I/O forum but will keep it open here also.
__________________
  #13
Old September 29th, 2006, 01:57 PM
Mystic Dragon Mystic Dragon is offline
[colour=null]If this is a Morse control, try setting the control in the neutral detent and then pulling the handle out. With Morse (or U.S. Marine) throttles, this poition will allow throttling up while not in gear.[/colour]
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
throttle control problem? JAL51974 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 16 June 1st, 2006 09:24 PM
Throttle control linkage problem fireman57 Johnson & Evinrude Outboards 4 April 26th, 2006 09:45 AM
throttle control problem fishallyear Mercury & Mariner Outboards 0 October 9th, 2003 08:55 AM
throttle control problem bipp Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 3rd, 2003 01:55 PM
throttle/Gas control problem RGR Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 September 5th, 2002 07:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
