  #1
Old January 19th, 2006, 07:44 AM
Tomorrow Came Tomorrow Came is offline
Default Gas Tank
Need ifo on replacing the gas tank on a 1990 2651 Ciera.
  #2
Old January 26th, 2006, 12:59 PM
Preachers Pastime Preachers Pastime is offline
Default Re: Gas Tank
Check out this link.Bayliner Boat owners club.It's the best.This site has already saved me tons of money.The link will take you to a thread that deal with fuel tanks..Good Luck http://p076.ezboard.com/fbocwebfrm26...age?topicID=69.
  #3
Old January 31st, 2006, 05:19 PM
Stratocaster Stratocaster is offline
That link has expired. Use this one instead. http://p076.ezboard.com/fbocwebfrm36...picID=20.topic
  #4
Old February 1st, 2006, 02:41 AM
Since I'm new to this site, I hope this info gets out to those who replied to my inquiry on replacing my fuel tank on a 1990 2651 Ciera. I too had quotes from mechanics in the $2,000 range, even had two "experts" tell me no way it can be done without pulling the engine. Wrong. It's simple math: the tank has a space above the sending unit/fill side that is open to the rear of the tank below the aft/mid cabin. A tape measure showed it to be 48" long. The width measurement is easy from the engine compartment and it's obvious how deep it is. Both cabin doors were larger than those measurements so it will come out. I took pictures but don't know how to share them with all of you. Diconnect all batteries and remove vent, fill hoses and sending unit wiring.The suggestion to drill holes in the cabin floor is the way to go. It gives you an idea where the open space ends and the stringers begin. Snap a line and start cutting, careful to set your depth of the blade to just larger than 1/2". Where a paper suit and mask; even with that I itched for 4 days! Once the floor is cut out, cut 10" up and across to take out a section of the rear wall. Use a sawzall to cut the corners around the tank that were glassed in. You need to lift the tank from the fill and feed pipe just enough to work a strap under the tank to the center. From the cabin lift the tank so the end closest to port tips out. Bring it out the two cabin doors! I cleaned the underside with Joy then sfter drying, lined the tank well with 1/2" styrofoam. I found a local fabricator that made me a new tank in 24 hours for $500! Set the new tank in, shim it as far to stern as possible then use spray foam in the four corners. Replace the support that was cut out with the floor with "l" brackets and atatch a piece of plywood under the piece of the rear wall to screw the floor piece to. The wall was replaced by using flat brackets on the inside wall. Silicone the cut and you're done! Don't forget to put gas back in!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
GAS tank removed 17 ft cobia, how do i find out which tank to put back delsol Boat Topics and Questions (not engine topics) 0 April 29th, 2006 06:27 AM
yamaha 1989 225 excel (oil from main tank draining back to remote tank . 9989 Yamaha & Suzuki Outboards 1 April 25th, 2005 07:08 AM
Fuel tank parts, old Mercury vacuum-type remote tank John Reynolds Mercury & Mariner Outboards 3 April 8th, 2003 12:34 PM
gas tank sending unit >>>> onboard tank kenthrussell Non-Repair Outboard Discussions 3 April 16th, 2002 06:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
