  #1
Old June 3rd, 2006, 01:35 AM
TheChad TheChad is offline
Default Aluminum Deep Vee Boat w/Mercury 115HP EFI 4-Stroke - What Prop Do you Have?
Hey All,I was hoping to find some other people with Aluminum Deep Vee Boat's that have the Mercury 115HP EFI 4-stroke, and find out what prop they have (Brand, Size, Material, etc), and what Results they get (Speed, Holeshot, RPM, etc).Currently I have a 2006 Lowe Fish & Ski 17' with a 2006 Mercury 115HP EFI 4-stroke.It came with a 19 Pitch Aluminum Prop. Which on a fully loaded boat (4-people & fishing gear) would run 40 MPH @ 5200 RPM.I Tried a Mercury Vengeance 18 Pitch Stainless Steel Prop. Which on a fully loaded boat (4-people & Fishing gear) would run 38-40 MPH @ 5400 RPMI then Tried a 17 Pitch Aluminum Prop. Which on a fully loaded boat (4-people & Fishing Gear) runs 42MPH & 5500 RPM.The 17P Prop was the only prop that will plane with 4-people behind the windshield.I also had the engine raised up 1 hole on the transom, which gave me a little better holeshot, and about 50RPM more.The Redline is 6000RPM, but it doesn't seam like I can get the engine to tach out to 6000RPM, and I am thinking if I go any lower in pitch I am going to start loosing Top end.The 18p Prop was the fastest when runing light (2-people light gear), which was 48MPH @ 5500RPMThanks,-TheChad
  #2
Old June 3rd, 2006, 04:42 AM
JB's Avatar
JB JB is offline
Default Re: Aluminum Deep Vee Boat w/Mercury 115HP EFI 4-Stroke - What Prop Do you Have
To the Prop Forum.
__________________
RED SKY at night. . .
JB
  #3
Old June 3rd, 2006, 08:17 PM
MurdockJr1 MurdockJr1 is offline
Sounds like I would go with a good 17 pitch stainless prop. It would suck not to be able to plane out with 4 people sitting behind the windshield. I have a 2002 Starcraft 170 LE with a 115 merc 2-stroke with a 20 pitch laser 2 prop and this thing will shoot out of the hole with 6 people behind the windshield. My boat is comparible in size and weight.Top end is 46mph with 2 people in the boat and turning max rpm.Just remember my motor is a 2 stroke and has a max rpm of 5250. I traded that engine in for a 90 hp merc 2 stroke because I didn't like the 2+2 idle system that merc uses on there 115 and 125 2 stroke classics. By the way the 90hp will shoot out of the hole just as fast as the 115 did and I only lost 2mph top end. And this is running the same prop as the 115. Good Luck
  #4
Old June 5th, 2006, 07:43 PM
stabbert stabbert is offline
I probably should of posted this here originally....very close to the same setup and disappointed as well as how the motor and prop were setup.Bought a Lund 1700 Fisherman late last fall with a 115 HP 4 Stroke Mercury. Just getting through the breakin period and starting to really see what the engine has. Right now I am not impressed as max RPM's are about 4800 and max MPH is about 36-37. Pitch on the standard Black Max prop that came with it is a 19. I called Lund Engineering for prop recomendations and they indicated that I should ensure the engine is mounted in the second hole so that the cavitation plate is equal or above the bottom of the hull. I took a look at the motor and currently it is about an inch or so below the hull and in the first hole. They also indicated I should upgrade to a Vengeance 18 pitch stainless steel prop. They indicated top speed with this config should be 41 - 46 MPH.Boat will be used as a fish boat mostly while pulling a tube once in a while. I would prefer to have a solid top end speed as we do hit some big lakes in Canada when we go up there that I want to be able to get across quickly but also want a decent hole shot.Thoughts? Suggestions? Info?Spencer
  #5
Old June 5th, 2006, 09:54 PM
walleyehed's Avatar
walleyehed walleyehed is offline
I've checked with Merc and the 2 props recommended for both rigs is either a 17P Trophy or a 17P Vengeance, then adjust engine heigth as needed to get max performance...The Trophy is of course a 4-bld, but I think they are saying bow-lift is needed and that would be why they recommend that. If we can get the bow up and free, it reduces drag creating more speed/RPM..the PVS holes allow adjustment for hole-shot.Now, with that being said, I'm not saying go buy one of those props....the Vengeance is just a entry-level SS prop, the Trophy has alot more high-tech features, and some lift is one of them.There are many props out there that will provide simular/ better/ worse performance, and finding the best prop for a 4-stroke has proven to be tough due to power-band differences....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop for 40hp 2 stroke yamaha on 16' aluminum startcraft *chris* Prop Questions and Topics 3 August 12th, 2006 12:15 PM
Aluminum Deep Vee Boat w/Mercury 115HP EFI 4-Stroke - What Prop Do you Have? TheChad Non-Repair Outboard Discussions 1 June 3rd, 2006 04:42 AM
Prop Diameter & Pitch Questions - 115hp EFI 4-Stroke TheChad Prop Questions and Topics 28 April 28th, 2006 01:20 PM
aluminum boat repair-deep gouges Boonebob56 Boat Topics and Questions (not engine topics) 11 September 19th, 2005 08:50 PM
aluminum boat repair-deep gouges Boonebob56 Johnson & Evinrude Outboards 1 September 16th, 2005 04:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
