  #1
Old April 11th, 2006, 05:56 PM
ROBERTSTELLJR ROBERTSTELLJR is offline
Default NEW BOAT,I THINK THE WRONG PROP IS ON IT
I JUST BOUGHT A 2001 18' MARADA BOWRIDER WITH A 125 MERCURY SALT WATER SERIES OB. THIS BOAT ONLY HAS 10 OR SO HRS OF TIME ON IT. I CARRIED IT OUT TODAY AND THE BOAT HAD NO BOTTOM END POWER AT ALL.IT SEEMED TO VENTILATE OR CAVITATE BADLY ONCE I DID GET GOING. ABOUT HALF THROTTLE I COULD THROW FULL THROTTLE TO IT AND IT WAS LIKE I WAS SPINNING WHEELS AND WASNT HOOKING UP.NOW IM LOOKING TO JUST PLAY AROUND WITH MY KIDS AND PULL THEM ON TUBES SO IM NOT TERRIBLY CONCERNED WITH A LOT OF MPH. THE PROP THAT IS ON THE BOAT IS A STAINLESS STEEL ONE AND HAS THESE NUMBERS ON IT BUT NO MANUFACTURER. 5120 20P THE MAX RPM IS 5250...CAN ANYONE TELL ME WHAT I SHOULD DO? THANKS ALOT, ROB
  #2
Old April 11th, 2006, 10:11 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Default Re: NEW BOAT,I THINK THE WRONG PROP IS ON IT
Sounds like maybe a spun hub...not uncommon.Best to take it to a prop shop, but you can verify slipage by marking the rear of the hub and make a mark on the housing in-line with each other..yellow grease pencil works well...then go run it and see if the marks still line up...if not, it's a spun hub. prop shop time.And welcome aboard!!
  #3
Old April 12th, 2006, 07:34 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Or maybe it's overventilated. Some stainless props have vent holes near the front of the blades. They can be plugged or restricted to fine-tune holeshot. A 20" pitch sounds a bit too steep for that set-up, the previous owner was probably going for speed. Only a good run with it not slipping would tell for sure. It's also possible that the motor is hanging too high in the back and the prop is grabbing air.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #4
Old April 16th, 2006, 07:43 AM
YEA I JUST PUT A 19 PITCH ALUMINUM PROP ON AND IT STRAIGHTENED OUT ALL THE PROBLEMS, THANKS ALOT,ROB
  #5
Old April 16th, 2006, 11:35 AM
walleyehed's Avatar
There is more to it than lowering 1" and fixing all the problems...something else was astray.Just for giggles, what is your max RPM now?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wrong prop? zeezer Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 July 15th, 2005 06:35 AM
Purchased a boat and cooled it the wrong way. Now I have leakage in boat & zeiden Mercury & Mariner Outboards 21 April 11th, 2005 02:14 PM
Did I buy the wrong prop? steam_mill Mercury & Mariner Outboards 3 April 7th, 2004 10:26 AM
Prop / prop shaft wrong on '67 V4 60HP Evinrude? Tinkerer2 Johnson & Evinrude Outboards 9 February 4th, 2004 05:06 AM
New prop doesn't fit - too long....is this the wrong prop? ZmOz Mercury & Mariner Outboards 6 August 30th, 2003 01:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
