Re: Laptop keyboard problem. Ya'll can breath deep now!
The restore process will fix the problem but you will likely lose everything done on the computer from today back to that date. You could also try this first, START, CONTROL PANEL, KEYBOARD, HARDWARE tab, PROPERTIES, DRIVER, and UNINSTALL. This removes the corrupt keyboard driver and when you reboot win XP will install a fresh good copy, this should solve this problem depending on how bad the registry is screwed up. I would suggest you buy a copy of a program like Norton System Works and then use AUTO UPDATE which keep your virus definitions up to date, NSW will also fix registry problems and a host of other computer problems. It even keeps WIN ME working on my spare laptop, ME is the (M)isery (E)dition of windows. I would upgrade but the unit was designed for ME and other versions won't install. Good luck,,,,,,,,, PS: NSW also includes a GO BACK restore program that works better that the WIN version since it's available even if the computer won't reboot into WIN.
