  #1
Old January 8th, 2006, 07:55 PM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
Default Houseboat prop ventilating
Happy new year guys and gals!!I've got a small problem, everytime I push the merc over 3500RPM the prop starts to suck air. I can't lower the motor without major structural changes to the transom, nor can I lengthen the leg (currently 20") because of other structual problems. The water pickup is not effected, it pee's fine at any RPM.The motor is a 2005 50HP EFI 4stroke bigfoot with an uncupped 14 x 10 (48-8543-42-445-10P).It is not a major problem as most of the time we are cruising around 2000RPM but every now and again I would like the extra ponies in high wind etc.Will a 9" pitch aleviate the ventilation? A 14 x 9 is within the reccommended size range for my boat (8 ton).Will cupping help?I would like to drop the motor down a few inches but until the boat gets slipped in 5 years or so that is not an option.Aldo
__________________
Watch this space......................
  #2
Old January 8th, 2006, 08:55 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Default Re: Houseboat prop ventilating
some cup would help greatly...If your RPM is close at WOT (which you may not know if it's venting) a 9P cupped should do wonders.It may be a case where a custom 8P is required.
  #3
Old January 9th, 2006, 11:27 AM
Dunaruna's Avatar
I was hoping you would say that.I think I will buy the 9" and get it cupped, even if it doesn't help the venting I can keep it for a spare.What's the skinny on reverse cupping?Thanks for the info.Aldo
__________________
  #4
Old January 9th, 2006, 01:11 PM
walleyehed's Avatar
Reverse hook props are a work of art on a houseboat application...great fwd AND reverse control....I haven't seen any under 10P though....
  #5
Old January 9th, 2006, 02:15 PM
Dunaruna's Avatar
Last 2 questions - I promise, how will reverse cupping affect the ventilation problem I am having and is it feasible for me to buy a new (non cupped) 9" and have the local prop shop reverse cup it?
__________________
  #6
Old January 9th, 2006, 03:53 PM
walleyehed's Avatar
The reverse hook props are still cupped in the fwd motion side as well..it's a fairly unique prop. The proplem with running a tripple cup as is used on some houseboats and pontoons, is they don't reverse well.If you had a 9P and added cup, it would be like a factory 11P un-cupped. I wish I had a pic of the reverse hook, cupped prop...the blade profile is different as well as the cup technique. Your 9P with a bit of cup may fix your main problem though.
  #7
Old January 9th, 2006, 06:05 PM
Dunaruna's Avatar
Thank you, the information you have shared is brilliant.
__________________
  #8
Old January 13th, 2006, 04:31 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Another thought. Maybe a "Whales Tail" would help. Since your prop seems to be sucking air from above, at the higher rpm's. You know that's the purpose of the "anti cavitation plate" just above the prop. And nowadays the engine mfgr's make them bigger than they used to so there must be something to it So if some is good, lots (whalestale) ought to be great.Don't know what it would hurt nor what the cost differential is.Last thought is that I'd bet the anticavitation plate on the reg 50 and the bigfoot are the same size even though the lower unit for the bigfoot made room to swing the big prop. So in turning the big prop, and pushing hard on the houseboat makes for increased opportunity to ventilate from the normal 50.Different approach worth considering. Might ask someone that uses a whales tale what it did for them....or just ask the mfgr.Mark
  #9
Old January 14th, 2006, 12:35 PM
Texasmark's Avatar
Just realized that I can and can't spell Whales Tail.....sometimes I am telling a "tale" about the whale.But I really do think it has merit to help in reducing the sucking air in from above (cavitation) problem and probably 1/3 the cost of a new prop.....and you can keep the mph you got or thought you were getting with your current prop at 3500 rpm's......I think.Mark
  #10
Old January 17th, 2006, 09:31 AM
ufm82 ufm82 is offline
Texas- he may not be sucking air from above. The pressure behind the prop is getting so low that the water actually boils, resulting in the ventilation. (Actually cavitation in this case.) They are two different issues. Wouldn't you agree walleye? I've heard of the props you mentioned but haven't seen one. Can you find a picture? UFM82
  #11
Old January 17th, 2006, 10:56 AM
Dunaruna's Avatar
No, it's not cavitation. It is definetly venting from the surface.The boat has a partially submerged 200 gallon fuel tank right in front of the motor, this tank also acts as a leg protector (don't panic, it's made from 1/4 inch plate steel and has very substantial bash plates). This tank causes a void around the leg when travelling above 10MPH. The problem is, I fitted new alloy pontoons that have allowed the boat to float 5" higher than it originally did, I was able to lower the motor only 2 inches. If I could have lowered the motor 5", I would not have a problem.BTW, the anti-vent plate on the bigfoot is 33% than the standard 50HP.Just a thought, are leg extensions available for the bigfoot? Maybe I'll ask in the merc forum.
__________________
  #12
Old January 17th, 2006, 01:03 PM
paulie0735 paulie0735 is offline
Hi Aldo, can you not add a simple bracket to the transom to get the engine back into the correct position?
  #13
Old January 17th, 2006, 01:14 PM
Dunaruna's Avatar
Maybe, but I need to slip the boat first (about $2500 out & in) and then remove the swim platform and have a closer look before I can start doing structural changes.This was taken in 2004 just after the motor was fitted, unfortunetly there was no way to anticipate the current problem.
__________________
  #14
Old January 17th, 2006, 04:39 PM
walleyehed's Avatar
Looking at the reflection off of 1 blade of the prop tells me YOU NEED SOME CUP!!!!!! You need some grab, bite, get-hold added to that prop....I feel it's going to continue venting like it is...Can you look down through the deck under power and see if the AV plate is quite a ways above the water???
  #15
Old January 17th, 2006, 04:48 PM
Dunaruna's Avatar
You're correct yoda, there ain't no cupping.
Quote:
Originally posted by walleyehed: Can you look down through the deck under power and see if the AV plate is quite a ways above the water???
Yes and yes, sort of.There are two plates on the bigfoot, the upper plate is out of the water at speeds above 10mph, the main anti-vent plate is just under or riding the surface.I'll get the 9" and get it cupped and next time the tub gets slipped I'll do some re-engineering to the mounting frame.As I said in the first post, it ain't a life and death problem, most of the time we are cruising around 5 mph.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Houseboat prop selection crokit Prop Questions and Topics 4 June 21st, 2006 04:36 PM
Prop Ventilating vs. Gimbal Problem rocklydockly Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 18th, 2005 03:44 AM
Why am I ventilating? Gus Mortimer Boat Topics and Questions (not engine topics) 6 July 26th, 2004 08:41 AM
prop ventilating albass Mercury & Mariner Outboards 6 July 17th, 2004 06:57 PM
Ventilating a prop k4m Mercury & Mariner Outboards 7 August 2nd, 2002 06:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
