  #1
Old September 22nd, 2005, 10:29 PM
boatster boatster is offline
Default Aluminum to Stainless. Which Prop? I have all stats listed Avon Rib 50 hp.......
Hi everyone.I want to run my boat faster or more efficiently. I have a 13' Avon Searider Ex Coastguard rib. It has a 50 hp 2 stroke Tohatsu with a 13.5 pitch 10 1/2" diameter prop. The motor is rated at 5800 rpms WOT. I am currently doing exactly that 5800 WOT. The boat is running around 35 mph on the gps.I have considered raising the motor 1 hole as I can trim the motor pretty far up and still maintain all the above. I also have the Nauticus tabs helping me out. Given all the info above could someone advise on what Stainless prop I should get? Michigan Wheel SS? Tohatsu SS ? Should I go up or down in pitch?Speed isn't as big as my desire to increase fuel economy. I'm going to raise the motor and see how that works but what would be a good SS prop? I want to retire the aluminum prop as a backup even though right now it seems to be doing a swell job.Please any advice info would be greatly appreciated. Thanks.Boatster
  #2
Old September 22nd, 2005, 11:31 PM
Triton II Triton II is offline
Ensign
Default Re: Aluminum to Stainless. Which Prop? I have all stats listed Avon Rib 50 hp...
Generally SS props are a little more efficient than alloy ones due to the stronger material which flexs less and the blades can be made thinner to increase their bite in the water. So going down an inch or so in pitch is often recommended. As an examople I have three props for my Yamaha FT60B - a 13.5 x 15 alloy, a 13.75 x 14 SS and a 13.75 x 13 alloy. The 15 and 14 give much the same revs and speed - about 5600 and 29 kts, the 13 gives 6100 and 27 kts and is much better out of the hole, it's used for tubing and waterskiing. Hope this helps.
  #3
Old September 23rd, 2005, 06:58 AM
walleyehed's Avatar
walleyehed walleyehed is offline
I would stay with the same pitch in SS and raise the engine to get the RPM back to 5800...the speed will be higher at the same RPM.
  #4
Old September 23rd, 2005, 10:26 AM
Thanks for the info guys. Walleyehed, I got the idea to raise the motor from you, reading all your other posts. How much higher do you think I could go? 1"? 2"? I trimmed the motor out almost 80% up on the tilt gauge and I didn't once hear the motor ventilate. My ventilation plate is just about right at the bottom of the boat. THe only reason I ask is because I need to drill an extra hole in the aluminum motor mount to raise it ( I'm at the bottom hole already ). Like I've said I really haven't been able to cause it to ventilate as I tilt the motor up within the tilt gauge range. Thanks again. Also which brand SS prop should I get? I can't find any 13.5 pitch propellers. On one of the blades my prop says 13.5. I need to measure the diameter again to be 100% sure what it is.How about the Michigan Wheels on sale at Iboats? http://www.iboats.com/mall/propfinde..._mode=standard
  #5
Old September 23rd, 2005, 10:44 AM
walleyehed's Avatar
I'd go with the 14 pitch if raising the engine.As for "how high" to go...well, that's one of those items that requires some testing. Standard bolt pattern holes are 3/4" from center to center on the top and you will likely be about 1-1/2" above the transom, or 1-1/2" above where you are now, at best with the Rapture.Mark locations at 3/4" so if the 1-1/2" is to much, you can drop 3/4" to take care of it.
  #6
Old September 23rd, 2005, 11:03 AM
So do you think the 14 pitch Michigan Wheel SS prop is ok? I feel a little cautious when I see it for $100 for a SS prop. Why so cheap? Otherwise I was thinking of going with an OEM Tohatsu SS prop for $225. How different can these props be from each other?I agree I think I'll raise it 1 1/2" and if it doesn't do so well I'll drop 3/4". Do you think drilling holes in the aluminum engine mount would cause any possible problems? Given of course I'm careful when drilling the holes. Would I weaken the transom mount any? I can't think of anything worse it'll do other than adding a few more holes where holes already exist right? I get a little nervous modifying things like an outboard
  #7
Old September 30th, 2005, 01:47 AM
HI Walleyehed,I'm about to buy the Michigan Wheel 14pitch Raptor prop from here on Iboats. Do you think this would be a good prop?
  #8
Old September 30th, 2005, 07:13 AM
walleyehed's Avatar
I think it would be just fine...The Rapture series is being replaced by a simular design with a bit different blade features. They just have a close-out price on the existing props in stock.
  #9
Old September 30th, 2005, 11:05 AM
Thanks again Walleyehed.I'm going to order that prop and raise my motor at least 3/4" and go from there. I'll report my findings.Boatster
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stainless or Aluminum Prop? Rushin Non-Repair Outboard Discussions 23 January 6th, 2003 06:08 PM
aluminum to stainless steel prop vettman Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 September 12th, 2002 10:32 AM
stainless vs aluminum prop h2oTherapy Non-Repair Outboard Discussions 4 May 6th, 2002 05:22 PM
Prop, aluminum vs. stainless gobydon Mercury & Mariner Outboards 2 October 11th, 2001 01:40 PM
Aluminum Vs Stainless Prop fritchey Johnson & Evinrude Outboards 4 August 23rd, 2001 10:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
