  #1
Old December 3rd, 2002, 04:39 PM
John avery John avery is offline
Default Pontoon Speed
I have a 1991 tracker bassbuggy 18ft with a 1991 40 hp evinrude. I have no bimini top or anything on the deck but the helm and the captains chair.At WOT I run 19 mph. Thinking of installing a 1987 75 hp merc. does anyone know what kind on speed I would gain? also this would give me Power trim and tilt. I dont have it with the 40hp. Any help would be appreciated.
  #2
Old December 3rd, 2002, 04:54 PM
DJ DJ is offline
Default Re: Pontoon Speed
averyj,Pontoons are "displacement hulls". They'll typically reach a certain speed and stay there unless grossly overpowered. Pontoons can be a bit tricky to select the right prop. Be more concerned about your top rpm. than speed.The 75 hp. may gain 3-4 mph, that's about it. What I'm concerned about is you overpowering the boat. If somethinng bad happens, you are automatically at fault.
  #3
Old December 4th, 2002, 02:36 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
averyj Just for comparison, I have a 20' toon and I run a '91 Rude 70 HP and get around 24 mph top end. 19 mph with a 40hp is very good speed! Sounds like you're set up properly and TNT won't make much difference on your toon. It is nice to have though! What is the Max HP your boat rated for?
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old December 4th, 2002, 10:54 AM
Rated for a 70 HP. Also feel the needed power would help pull my son on a tube.ThanksJohn
  #5
Old December 4th, 2002, 11:02 AM
mattttt25 mattttt25 is offline
averyj,you're gonna get lectured for putting more power on than its rated for, but i think the 75 will help pulling your son. good luck-
__________________
2002 Wellcraft 290 Coastal
Twin 2002 Yamaha F225s
  #6
Old December 4th, 2002, 11:37 AM
averyj To get a jump on the Lecture that is coming, Overpowering your boat will most likely void any insurance claim and may be illegal or not, depending on where you boat. Check with your insurance company first and see what they say. Now on to the issue at hand. A 75 HP is not a significant difference, as opposed to the 70 HP rating. As long as your hull will handle a 70, you should have no problems with the 75 HP. You will definitly be able to pull a tuber and probably a light skier on 2 skies(I have)! I personally like the extra power on a toon, as I feel that you can never have enough on that type of hull design. If I had my way, I'd be running a 25'er, 3-Log, with a 200HP hangin off the back. And it WILL plane out, so to speak. But work with what you got and check all the regulations before you swap over to the larger motor. Good Luck with it,
__________________
Rick
  #7
Old December 4th, 2002, 04:04 PM
Thanks Guys, it will be a few weeks and I will post just what happens to my toon with the upgraded motor. At this time the boat is not insured so I will get the details from them before the motor installation if there is any problems I will hold off until my dealer gets a used 70 HPJohn
  #8
Old December 5th, 2002, 06:31 AM
rogerwa's Avatar
rogerwa rogerwa is offline
If you have bigger tubes 23"+ I beleive you will get a bigger bang than if you have 19" tubes. On my 21ft with 19" tubes, most of the tubes was in the water. The more power the more resistance. On larger tubes where most of the tube is out of the water, you may acutally get some semi planing action.If you have larger tubes, installing lifting strakes may help in getting more speed as well..I have also seen an aftermarket center lift tube that will basically lift toons out of the water much like a hydrofoil.Just my .02..
__________________
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
-Thomas Jefferson
  #9
Old December 5th, 2002, 06:35 AM
DJ DJ is offline
averyj,My brother owns a 20' Starcraft toon with a 1998 75 hp. Merc. He runs an 11" pitch prop. (top rpm-5750) and gets right at 25 mph.-with a light load.
  #10
Old December 5th, 2002, 02:25 PM
My Toons are 21 inches in OD/Diameter. It does seem with the 40 Hp I get Planing action, anyways bad news today, insurance company wont insure my toon if its even 1 Hp over the plate rating. So looks like I will tell my merc. man to hold off until he gets a good 70 or maybe a 60 hp.John
  #11
Old December 5th, 2002, 02:49 PM
averyj,Glad you found out beforehand about the insurance. I'm not sure about the Mercs, as I run OMC products, but I don't think there will be much weight difference between the 60 and 70 HP. So either one would be a good choice. The reason I am bringing this up, is that you will definitly notice the extra weight in the back end with a 70 HP on there and having 19" Logs. It will squat quite a bit while sitting still and at low speed. But if a good one comes along, I'd opt for the 70! Good Luck,
__________________
Rick
  #12
Old December 5th, 2002, 03:04 PM
My toons are 21 inches and at this time I have Omc Power.ThanksJohn
  #13
Old December 5th, 2002, 03:09 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
I have a 20' toon with 50hp 4 stroke. Top speed is 19.5mph per gps @ 5600rpms. Pontoons are 23" dia. All up weight is about 2400lbs + passengers. 4 passengers and 1 120lb kid being pulled on a tube bring the top speed down to 15mph.
  #14
Old December 5th, 2002, 03:17 PM
Thanks for info BillPJohn
  #15
Old December 5th, 2002, 04:03 PM
This will get you going!! Check out the GPS Speeds. web page
__________________
Rick
  #16
Old December 5th, 2002, 04:10 PM
Or maybe this???
__________________
Rick
  #17
Old December 6th, 2002, 02:35 AM
DJ DJ is offline
Do you have to pedal it to get it started? Ala-Moped!
  #18
Old December 6th, 2002, 08:52 AM
495v 495v is offline
I'D LOVE TO SEE THAT THING RUN. NOTHING LIKE A LEISURE STROLL AROUND THE LAKE!
  #19
Old December 6th, 2002, 11:08 AM
KennyKenCan KennyKenCan is offline
Location: Fire Island, Long Island, NY USA Where the Bay and the Ocean meet the Beach
Hope you have insurance on that bimini, don't look like it will be on there all too long!
  #20
Old December 6th, 2002, 01:48 PM
Rickb1BoatThis web site is just what I may be looking forThanksJohn
  #21
Old December 6th, 2002, 01:49 PM
Bart Sr.'s Avatar
Bart Sr. Bart Sr. is offline
That is a very cute balloon!!!!!!THANKFULLY AND RESPECTFULLY>>BART SR.
__________________
In Loving Memory--Sgt.Chad Allen 1981 - 2007
Link to LAR Memorial
http://i704.photobucket.com/albums/w...ARMemorial.jpg
Support All of our troops until they ALL come home.
Thankfully and Respectfully>>>>Bart Sr.
  #22
Old December 6th, 2002, 02:45 PM
coupedeville coupedeville is offline
Fast enough for you? [IMG]D:\Boating\pontoon.jpg[/IMG]
  #23
Old December 8th, 2002, 05:23 PM
snooks2005 snooks2005 is offline
averyj does your merc guy buy used engines?
  #24
Old December 8th, 2002, 05:36 PM
Yes he rebuilds them if needed then sells theminstalled and rigged for about $1800.00 50hp to 90 hp I dont know what higher hp prices are but to answer your question Yes.John
  #25
Old December 8th, 2002, 05:57 PM
averyj I am looking to sell my 1998 50 mariner 4 stroke big foot.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Actual mph(speed) comparisons.Post your highest speed. Michael Belcher Boat Topics and Questions (not engine topics) 38 April 30th, 2007 12:59 PM
Slow speed & High speed Needles C/W packing sanssouci Johnson & Evinrude Outboards 9 March 21st, 2007 02:34 PM
pontoon boat + speed+ clueless driver + sandbar = OUCH! reddog349 Stupid Human Tricks While Boating/Fishing 5 July 6th, 2005 06:34 PM
35' pontoon trailer for 28' pontoon???? whatsadixie Trailers and Towing 3 May 22nd, 2003 06:01 AM
pontoon speed oaker 1 Mercury & Mariner Outboards 1 May 3rd, 2002 07:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
