Re: 45Hp Chrysler, Internal water tube issue
Well ---Its never easy!!!!!!!!!!<br />Sadly the grommet at top of the water tube is no longer present. Leaves me no choice but to split power head and leg.<br />Probably for the best,(do it once do it well)I will replace thermostat and impellor since I am that close, plus a quick clean up of the water galleries via the exhaust cover that i had removed and i shouldn't be far off a decent cooling system overhaul --- HMMMMMMMMMM-- will not have done cylinder head and block galleries?? Pull the head and do it?? Damm got to stop somewhere before replacing a waterpipe ends up in a complete motor dismantle!<br />As I have good compressions 127 & 130 i think best left alone and just back flush system when rebuilt.<br />I would value your opinion on my logic?<br /><br />Re: Spanners to fit the 8 powerhead/leg screws.<br />They are 12 spline double hexagonal headed screws which due to corrosion I believed were 9/32 wrench size.Double hexagonal(12 teeth)9/32 sockets and ring spanners are no longer available- not made-.<br />Today i got two screws out with a 1/4" wrench just gripping,so I believe i was mistaken and they started their life as a more standard 1/4".<br />Therefore it is now time to weld bolts onto the heads of these ugly little creatures and remove them to the rubbish bin, and curse the days wasted searching manufacturers for 9/32 spanners to save their worthless little lives.<br /><br />AHHHH it must be the challenges we overcome that give us a sense of achievement
