Re: 1996 force impeller change
4 bolts (2 bolts on each side of the lower unit.)<br />1 nut up in the trim tab pocket.<br /><br />And then disconnect the shift shaft.<br />On the starboard side just above the lower unit, there is a coupler nut, held in position with a jam nut.<br />Loosen the jam nut, then turn the coupler nut the other way to disconnect the shift shaft.<br /><br />Lower unit should drop down, will maybe need a little gentkle persuasion.
