Something is wrong here. I have a 1998 50hp. When I turn the key, the starter engages the flywheel and turns over the motor and then disengages, however the starter drive assembly keeps spinning when disengaged. Shouldn't it stop spinning after disengaging? When motor is put in gear it stops spinning until returned to neutral. When lever is positioned back to neutral, starter briefly engages flywheel again and then disengages and keeps spinning. This makes a kling sound every time the lever is returned to neutral. It's a brand new starter, but old one did the same. I don't want to replace this one anytime soon. Any suggestions. <br /><br />Thanks,<br /><br />Rob
