lukethorwart
- May 8, 2005
- 28
I have seen similar questions asked about this topic, however my situation is a bit different and I am looking for advice.<br /><br />Sometimes when turning the key, the starter will spin at the correct speed but will not pop up to engage flywheel. If I go back and lightly tap on the side of the starter it with a wrench, it pops up without a problem the next time I turn the key.<br /><br />This usually tends to happen at the ramp. If I'm out for awhile, shut her down at some point, and then try to start her back up, it typically works fine. <br /><br />I have seen the term "bendix" in some of my searching, I was wondering what that is and if it could be the problem?<br /><br />Any advice would be appreciated.<br /><br />Luke
