Chrysler Ignition wiring
schmaky1
I had to install a new ignition module for my 70 hp Chrysler outboard. I went with the CDI Electronics model #115-3301 and have attached all the wires except for one, it is a white/black wire that is suppose to connect to the distributor I think. Does anyone know where on the distributor I connect it to. Can any screw work or does it need to be on a certain one. Thanks for any help you can give me.
novicetech
Re: Chrysler Ignition wiring
Yes it needs to be hooked up to the points connection or the closest connection to the black ground wire (if electronic ignition) on the distributor. There should be a screw with a nut on it for the connection.
