Hi..I am new to boating and just got my first boat on the water. Engine starts ok with a little throttle open and running ok at low to med rev's. However when I open it up a bit to higher rrm or even full throttle, the engine stutters. It appears to be running at well under it top rpm and then for a brief second or two jumps to high rev and back down again. My thinking is along the line of fuel, and the engine not getting enough but it is a new tank and feed hose(correct size I hope) and the fuel filter/hand pump in the right way (checked) Check spark plus and engine runs at lower revs with no problems although seem to struggle a bit at very low revs. Haven't got a clue when it comes to engines so any sensible help would be appreciated. Many thanks<br /><br />Andy
