Re: 70's chrysl. fires but, doesn't run
First off, never use starting fluid on a two-stroke. It is like running a 4-stroke without oil---bad news. Use "Sea Foam Deep-Creep" in the spray can for decarbing the engine. But also, it doubles as a great two-cycle starting fluid. I keep a can onboard just in case. But you're on the right track with the fuel pump.<br /><br />The problem is carb or fuel delivery.<br />My first attack to this problem on that motor would be to disconnect the fuel line at the carb, put the line in a jar ,and hit the starter. If it pulses fuel, it's ok. I highly suspect you'll need to order a new fuel pump kit. The diaphram fails about every other year under normal conditions. This is because of the enhanced ,no-lead formulations of modern fuels.<br />The alcohol eats the rubber.<br />If it did pulse fuel, the problem is a clogged pick up tube, or other orafice in the carb.<br />Finaly, check compression. The reason being that the fuel pump operates on the motor's compression...No, or low compression=motionless diaphram=no fuel delivery.
