Mattfishin
- May 22, 2005
- 4
The motor runs at great temps untill it is at full throttle and it runs at 190 degrees F at the cylinder head. Is this the correct temp or is it hot like i have been told???? The motor has new water pump, i pulled the power head and the exhaust and the were no blockages the replaced the gaskets. I also to the T-sat out because with it in the cyl. head was running temps from 190-250.
