MontanaBob
- May 19, 2005
- 6
This motor will start 1 out of 10 times in a test tank. When it doesn't start, there is no spark but the starter cranks and cranks. I followed the manual and with a volt meter checked the batery
k, checked the starter: ok, etc. got to the ignition switch and it didn't register 12 volts. Manual said to replace. I replaced it and $32 later it didn't change anything. Still no start, no spark. Points are next on the list in the manual.... Doesn't look like an easy job so I thought I would solicit opinions first. Could this be a grounding problem? Any help is very appreciated.
