Where to find part # for force 150 stator
Quick Cal
I belive I found the problem with my motor. I found a rigged up wire going to the stator. Someone actually put a cable tie on it tring to hold it tight against the stator to make contact. I guess from it arcing it made the stator burn up.<br /><br />I called the local shop and from my #'s she seem's to think my motor is a 90, but didn't seem to sure at all. It's supposed to be a 89. Can anyone confirm these #'s, and tell me if this is the correct part #. <br /><br />Model# 1508E9A<br /><br />Serial# 017996<br /><br />The part # she say's is right,,,<br /><br />300F721095-1<br /><br />Also, can you guy's recomend any good part's source's. Thank's, Cal
roscoe
Re: Where to find part # for force 150 stator
Model number 1508E (9) A <br />The "9" is the year indicator. So this is a 1989(A) motor.<br /><br />Stator part number 300-888793<br /><br /><br />See item number 4 here : <br /> http://www.mercruiserparts.com/Show...16&bnbr=40&bdesc=IGNITION+SYSTEM+89A+THRU+91A <br /><br />Still not cheap, but they are offering it at a 15% discount. This is a genuine Mercury part.<br /><br />But I think you may be able to get an aftermarket stator from Seiler Marine dot com, part number 176-3095 for $155 <br />Confirm before ordering from here.
Quick Cal
Thank's roscoe,,,you da man. Ya, I don't know what the big confusion is on the year. Two shop's seem to think it's a 90, and one shop is sure it's a 89. The 89 guy's part is $175, gaurenteed to be here the next day. The other shop's part is $350+, and would take 5 day's. I went with the guy that was sure. Hope he's right,,,,lol. Cal
