Well I just purchased a 1988 Bayliner with a Force 125. The problem is that the motor took a big hit in shallow water which broke off the fin on the lower unit which is right before the prop. The previous owner said that he changed the prop and kept using the boat. <br /><br />I havent had the boat in the water yet but the lower unit has a lot of back-and-forth movement in it. If you take the cover off, you can see the block moving together with the lower part. Are there any mounts that could have been damaged to cause this or is the movement normal?<br /><br />Also, the prop moves back and forth (about 1/4 to 1/2 an inch) on the shaft as well. It cannot be tightened anymore then it already is. Does it mean that it is not the right prop for the motor? I appreciate any help. <br />Thanks!
