Thanks for any help at all, everyone! I ended up with what appears to be a very clean chrysler 55 longshaft outboard motor (modelguides say 1970-75 - ser# 555 HG 4265), only I believe it's missing some parts in the electrical system. I'm hoping I can tackle this, purchase necessary parts, hook them up and try and crank it.<br /><br />I downloaded and printed out the service manual only it's not terribly clear to me since it covers a number of different models it seems. <br /><br />There's a starter mounted with no wire(s) connected to it, I see no rectifier or ignition coil(s) at all (not even the double coil bracket is there), and the manual has pictures of a fuse box or something that is not on mine. The terminal block doesn't match the manual's schematic, either. Mine has 8 possible wires with the following breakdown (top to bottom):<br />yellow - "starter" (disappears into the harness)<br /><blank> - empty, no label nor wire connected<br />white - "mag tach" (only attached wire is black and goes up under flywheel)<br />green - "choke" (seems to go there alright)<br />orange - "heat" (goes to thermostat, right?)<br />red - "battery" (disappears into harness)<br />blue - "magneto" (actually blk wire and couples with "white" above, runs up under flywheel)<br />black - "ground" (was cut, so I pulled out of harness).<br /><br />Thanks for any help at all!<br />-brad
