Realgun
- Jul 31, 2003
- 2,484
I have a 1988 85 Hp Force 856X8a.<br />I am replacing just about everything and the switch is included in that also. The only issue is that on the switch is 2 M's. I know from the diagram 1 is + the other is ground.<br />
<br />On the engine is a label that states the color is white and blue. I have both at the old switch. Also there is a white wire that goes to the kill switch too on both of these.<br />Problem is there is no indication of + or - .<br />I hooked up a wire to ground at the battery, battery was not installed, The with was 0 ohms and the blue was 1 meg ohm. I am going to assume the 0 ohm which is white is the correct ground.<br /><br />Any comments as to am I right or will I blow up something?<br /><br />BTW the switch did turn the engine and click the selanoid so I thing I got that correct at least.
