Re: WOT testing, where/how
Before you mess with main jets, make sure they have not already been changed. If the engine originally came from a low elevation to your location, or was originally delivered in your area, the jets may very likely already correct. Always make sure what you have or don't have before making modifications like this. You would be well advised to make a few test runs with an accurate speedometer or GPS. Note speed, engine trim setting, and RPM at wide open throttle. You need to get prop selection correct first. As pointed out earlier, a prop with less pitch raises RPM, one with more pitch decreases RPM. When you have that figured out, make some runs and check spark plug color. White insulator = lean, light tan = OK, sooty/blackish = rich.
