Re: Setting the timing on a 1996 50 force / Mercury
It is very difficult to set the timing on a outboard.Unless someone has changed it,you shouldn't mess with it.What's the motor doing that you suspect the timing is out?
hey there i also have a older 86 force 50hp that has the same starting problem. the coils an wires have been replaced an there is still no fire to the motor any suggestions for that?
