Re: Newbie Force buyers guide needed
when you get a force the first thing ya wanna do is change the impeller kit, t-stats and pressure contols, remove the head gasket and replace it clean the carbs and rebuild the fuel pump. also clean the puddle drains,later called a recirc system. if its a brunswick force with a black stator save money to replace it with the red stator kit when it fails. the kit is rather pricy
.my experince with chysler,USMarine and later brunswick stuff has led me to some conclusions. 1 is 3,4 and 5 cyl motors pop head gaskets every few years for no apperant reason. if replaced as a maint procedure they never fail. the recirc screens clog rather easy. the fuel pumps last 2 or 3 years and can fail. the water pumps/housings fail in 3 years or less and most people that own a force can barly make the payments on the rig and do zero maintenance
. so be aware that most likly nothing was ever done. get any and all maint and repair reciepts.
