Re: 85hp FORCE OVERCHARGING.
Hazarika,<br /><br /> I ordered a Universal Regulator (Model 090, for 200 watts or less and an electic start) and put it in place of the rectifier. I spoke to the shop that ordered it for me and was told it came from Parts Unlimited. The shop mentioned to check out the Dennis Kirk website and the regulator should be on there. I am in the office now, however, if you still need more information I will get the part number off the regulator when I get home. I can also send you a digital photo of the installation if you like. For the record, I installed the the regulator almost 2 years ago and the voltage has been regulated to less than 14 volts and the battery stays charged.<br /><br />Good luck.
