Re: Chrysler 9.9 hp outboard..
lots of them still out there, uncomplicated as you can get, not very fuel good on fuel(not that a 9.9 can burn much...it was a crossflow if i rember right,squirt some storage seal into the cylinders, do a compression check,&spark check if thats okay check gearcase for oil, do a water pump and carb kit & fire her up...<br />Good luck
